跳转到主内容
Numark TT1600 Audio Jacks Replacement
你所需要的
  1. Numark TT1600 Audio Jacks Replacement, Audio Jacks: 步骤 1 中的图像 1,1
    • Flip over the turntable and remove the nine screws on the outer edges.
  2. Numark TT1600 Audio Jacks Replacement: 步骤 2 中的图像 1,2 Numark TT1600 Audio Jacks Replacement: 步骤 2 中的图像 2,2
    • Find the audio jacks located on the back side of the turntable.
    • Remove the screw located in between the right and left audio jacks.
  3. Numark TT1600 Audio Jacks Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover by pulling it apart.
  4. Numark TT1600 Audio Jacks Replacement: 步骤 4 中的图像 1,1
    • Remove the grounding hardware located next to the audio jacks.
  5. Numark TT1600 Audio Jacks Replacement: 步骤 5 中的图像 1,2 Numark TT1600 Audio Jacks Replacement: 步骤 5 中的图像 2,2
    • Remove the ground screw and washers.
  6. Numark TT1600 Audio Jacks Replacement: 步骤 6 中的图像 1,1
    • Remove the remaining nut and washer.
  7. Numark TT1600 Audio Jacks Replacement: 步骤 7 中的图像 1,1
    • Remove the screw located on the back panel of the audio jack housing.
  8. Numark TT1600 Audio Jacks Replacement: 步骤 8 中的图像 1,3 Numark TT1600 Audio Jacks Replacement: 步骤 8 中的图像 2,3 Numark TT1600 Audio Jacks Replacement: 步骤 8 中的图像 3,3
    • Remove the screw that connects the audio jacks to the biggest circuit board via wire.
  9. Numark TT1600 Audio Jacks Replacement: 步骤 9 中的图像 1,1
    • Gently pull out the audio input jacks from the audio input housing.
结论
另外一个人完成了本指南。
Nikolai
于10/12/11注册
254 声望
创作了5篇指南
团队
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G14
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,379
