跳转到主内容
Numark N4 USB Port Replacement
你所需要的
  1. Numark N4 USB Port Replacement, Numark N4 Disassembly: 步骤 1 中的图像 1,1
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Numark N4 USB Port Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Numark N4 USB Port Replacement: 步骤 3 中的图像 1,1
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  4. Numark N4 USB Port Replacement: 步骤 4 中的图像 1,1
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  5. Numark N4 USB Port Replacement: 步骤 5 中的图像 1,1
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  6. Numark N4 USB Port Replacement: 步骤 6 中的图像 1,1
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  7. Numark N4 USB Port Replacement, USB Port: 步骤 7 中的图像 1,1
    • Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
  8. Numark N4 USB Port Replacement: 步骤 8 中的图像 1,1
    • Carefully remove the circuit board from its housing.
  9. Numark N4 USB Port Replacement: 步骤 9 中的图像 1,1
    • Locate the USB on the circuit board.
    • Using a soldering station, carefully desolder the connection points to the USB outlet.
    • To review soldering safety and techniques, please visit 如何焊接和拆焊.
结论
4等其他人完成本指南。
Erik Charlton
于10/10/17注册
789 声望
创作了5篇指南
团队
USF Tampa, Team S13-G11, Cagle Fall 2017 USF Tampa, Team S13-G11, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G11
4 名成员
创作了12篇指南
一条评论
i we like to get the new board of dis numark n4
daniel benson - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 19
总计 2,353
