跳转到主内容
Numark N4 Audio Jack Replacement
你所需要的
  1. Numark N4 Audio Jack Replacement, Numark N4 Disassembly: 步骤 1 中的图像 1,1
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Numark N4 Audio Jack Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Numark N4 Audio Jack Replacement: 步骤 3 中的图像 1,1
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  4. Numark N4 Audio Jack Replacement: 步骤 4 中的图像 1,1
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  5. Numark N4 Audio Jack Replacement: 步骤 5 中的图像 1,1
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  6. Numark N4 Audio Jack Replacement: 步骤 6 中的图像 1,1
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  7. Numark N4 Audio Jack Replacement, Audio Jack: 步骤 7 中的图像 1,1
    • Turn the panel around so that the audio jack is facing forward as shown.
  8. Numark N4 Audio Jack Replacement: 步骤 8 中的图像 1,1
    • Using a soldering station, carefully desolder the connection points around the audio jack and remove it.
    • To review soldering safety and techniques, please visit 如何焊接和拆焊.
结论
2等其他人完成本指南。
Erik Charlton
于10/10/17注册
789 声望
创作了5篇指南
团队
USF Tampa, Team S13-G11, Cagle Fall 2017 USF Tampa, Team S13-G11, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G11
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 532
