跳转到主内容
修复你的物品
维修的权力
商店
简介
How to replace the glass screen on the NuVision 10.1 Atom. Be careful handling the lithium battery as they are prone to exploding when bent or punctured. Also, make sure to carefully remove the glass screen. If the glass breaks, there is a chance of cutting yourself.
  1. Turn the device screen side down. Carefully remove the back piece with the iFixit opening tool. Carefully remove the back piece with the iFixit opening tool.
    • Turn the device screen side down.
    • Carefully remove the back piece with the iFixit opening tool.
  2. Remove the yellow tape covering the motherboard gently with your fingers.
    • Remove the yellow tape covering the motherboard gently with your fingers.
  3. Pull the camera plug upward and away from the motherboard with your fingers. Gently pull the camera from the device. The camera is held by tension. Gently pull the camera from the device. The camera is held by tension.
    • Pull the camera plug upward and away from the motherboard with your fingers.
    • Gently pull the camera from the device. The camera is held by tension.
  4. Carefully remove silver tape with your fingers.
    • Carefully remove silver tape with your fingers.
  5. Remove speakers gently using your fingers, they pop out easily. Disconnect cords attached to the speaker from white pod.
    • Remove speakers gently using your fingers, they pop out easily.
    • Disconnect cords attached to the speaker from white pod.
  6. Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
    • Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
  7. Gently remove the battery's three ZIF connectors from the motherboard. Use your fingers. Be careful not to puncture the battery. Be careful not to puncture the battery.
    • Gently remove the battery's three ZIF connectors from the motherboard. Use your fingers.
    • Be careful not to puncture the battery.
  8. Disconnect the battery's bundled cable connector from the motherboard with fingers. Disconnect the battery's bundled cable connector from the motherboard with fingers.
    • Disconnect the battery's bundled cable connector from the motherboard with fingers.
  9. Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily. Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily. Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily.
    • Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily.
  10. Pry the battery away from the display screen gently using a nylon spudger or the plastic opening tools. Using a metal spudger may bend or puncture the battery. Lithium batteries are prone to explode. There is a lot of adhesive, take your time and be careful.
    • Pry the battery away from the display screen gently using a nylon spudger or the plastic opening tools.
    • Using a metal spudger may bend or puncture the battery. Lithium batteries are prone to explode.
    • There is a lot of adhesive, take your time and be careful.
  11. Remove six silver 2.8mm screws surrounding the battery using the Phillips #000 screwdriver. Remove six silver 2.8mm screws surrounding the battery using the Phillips #000 screwdriver.
    • Remove six silver 2.8mm screws surrounding the battery using the Phillips #000 screwdriver.
  12. Remove tape securing the camera to the device gently using your fingers. Pry display screen away from screen glass gently using your fingers. Pry display screen away from screen glass gently using your fingers.
    • Remove tape securing the camera to the device gently using your fingers.
    • Pry display screen away from screen glass gently using your fingers.
结论
另外一个人完成了本指南。
Carly Daniele
于2019年02月14日注册
559 信誉积分
创作了5篇指南
团队
USF Tampa, Team S1-G5, Leahy Spring 2019 USF Tampa, Team S1-G5, Leahy Spring 2019 的会员
USFT-LEAHY-S19S1G5
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 3
过去的30天: 7
总计 120
