当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove speakers gently using your fingers, they pop out easily.
Disconnect cords attached to the speaker from white pod.
Pry the battery away from the display screen gently using a nylon spudger or the plastic opening tools.
Using a metal spudger may bend or puncture the battery. Lithium batteries are prone to explode.
There is a lot of adhesive, take your time and be careful.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
