跳转到主内容
NuVision 10.1 Atom Battery Replacement
你所需要的
  1. NuVision 10.1 Atom Battery Replacement, Camera: 步骤 1 中的图像 1,3 NuVision 10.1 Atom Battery Replacement, Camera: 步骤 1 中的图像 2,3 NuVision 10.1 Atom Battery Replacement, Camera: 步骤 1 中的图像 3,3
    • Turn the device screen side down.
    • Carefully remove the back piece with the iFixit opening tool.
  2. NuVision 10.1 Atom Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the yellow tape covering the motherboard gently with your fingers.
  3. NuVision 10.1 Atom Battery Replacement: 步骤 3 中的图像 1,3 NuVision 10.1 Atom Battery Replacement: 步骤 3 中的图像 2,3 NuVision 10.1 Atom Battery Replacement: 步骤 3 中的图像 3,3
    • Pull the camera plug upward and away from the motherboard with your fingers.
    • Gently pull the camera from the device. The camera is held by tension.
  4. NuVision 10.1 Atom Battery Replacement, Speaker: 步骤 4 中的图像 1,1
    • Carefully remove silver tape with your fingers.
  5. NuVision 10.1 Atom Battery Replacement: 步骤 5 中的图像 1,2 NuVision 10.1 Atom Battery Replacement: 步骤 5 中的图像 2,2
    • Remove speakers gently using your fingers, they pop out easily.
    • Disconnect cords attached to the speaker from white pod.
  6. NuVision 10.1 Atom Battery Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
  7. NuVision 10.1 Atom Battery Replacement: 步骤 7 中的图像 1,3 NuVision 10.1 Atom Battery Replacement: 步骤 7 中的图像 2,3 NuVision 10.1 Atom Battery Replacement: 步骤 7 中的图像 3,3
    • Gently remove the battery's three ZIF connectors from the motherboard. Use your fingers.
    • Be careful not to puncture the battery.
  8. NuVision 10.1 Atom Battery Replacement: 步骤 8 中的图像 1,2 NuVision 10.1 Atom Battery Replacement: 步骤 8 中的图像 2,2
    • Disconnect the battery's bundled cable connector from the motherboard with fingers.
  9. NuVision 10.1 Atom Battery Replacement: 步骤 9 中的图像 1,3 NuVision 10.1 Atom Battery Replacement: 步骤 9 中的图像 2,3 NuVision 10.1 Atom Battery Replacement: 步骤 9 中的图像 3,3
    • Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily.
  10. NuVision 10.1 Atom Battery Replacement, Battery: 步骤 10 中的图像 1,3 NuVision 10.1 Atom Battery Replacement, Battery: 步骤 10 中的图像 2,3 NuVision 10.1 Atom Battery Replacement, Battery: 步骤 10 中的图像 3,3
    • Pry the battery away from the display screen gently using a nylon spudger or the plastic opening tools.
    • Using a metal spudger may bend or puncture the battery. Lithium batteries are prone to explode.
    • There is a lot of adhesive, take your time and be careful.
结论
Carly Daniele
于02/14/19注册
567 声望
创作了5篇指南
团队
USF Tampa, Team S1-G5, Leahy Spring 2019 USF Tampa, Team S1-G5, Leahy Spring 2019 的会员
USFT-LEAHY-S19S1G5
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 846
