跳转到主内容
Novatel MiFi 2200 Circuit Board Replacement
你所需要的
  1. Novatel MiFi 2200 Circuit Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Circuit Board Replacement, Case: 步骤 3 中的图像 1,1
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Once the seal has been broken all the way around, open the cases using your hands.
  5. Novatel MiFi 2200 Circuit Board Replacement, Circuit Board: 步骤 5 中的图像 1,1
    • To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
  6. Novatel MiFi 2200 Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Simply pick up the circuit board with your fingers and remove it from the case.
  7. Novatel MiFi 2200 Circuit Board Replacement: 步骤 7 中的图像 1,3 Novatel MiFi 2200 Circuit Board Replacement: 步骤 7 中的图像 2,3 Novatel MiFi 2200 Circuit Board Replacement: 步骤 7 中的图像 3,3
    • Apply double-sided stick tape to the inner top and bottom halves of the device along the seam that was previously unsealed.
    • Snap the two halves together along the adhesive line to reconnect it as it previously was.
结论
After the circuit board is replaced the device should function properly again. When reassembling the device, keep in mind that you will need adhesive to keep the device together.
6等其他人完成本指南。
Justin Russo
于04/15/12注册
196 声望
创作了3篇指南
团队
Cal Poly, Team 7-36, Maness Spring 2012 Cal Poly, Team 7-36, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G36
5 名成员
创作了5篇指南
3条评论
Hello, where do you purchase the new circuit board?
David - 回复
I've tried every thing to get this device to work properly. Sic results. Sic.
Clennis Jones - 回复
Where and how can I get this thing replaced?
Clennis Jones - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 2,187
