简介
If major problems occur with the device and problems still can not be fixed after following troubleshooting guides, there may be a circuit board issue. This guide gives instructions on how to replace a broken circuit board.
工具
配件
无需配件。
Remove the rear cover by pressing down on the cover and pulling it away from the device.
To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
After the circuit board is replaced the device should function properly again. When reassembling the device, keep in mind that you will need adhesive to keep the device together.
6等其他人完成本指南。
3条评论
I've tried every thing to get this device to work properly. Sic results. Sic.
Where and how can I get this thing replaced?
