跳转到主内容
Novatel MiFi 2200 Case Replacement
你所需要的
  1. Novatel MiFi 2200 Case Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Case Replacement: 步骤 2 中的图像 1,1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Case Replacement, Case: 步骤 3 中的图像 1,1
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Case Replacement: 步骤 4 中的图像 1,1
    • Once the seal has been broken all the way around, open the cases using your hands.
结论
2等其他人完成本指南。
Justin Russo
于04/15/12注册
196 声望
创作了3篇指南
团队
Cal Poly, Team 7-36, Maness Spring 2012 Cal Poly, Team 7-36, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G36
5 名成员
创作了5篇指南
一条评论
If case gets damaged, is there a place to but the case
Snehraj Merchant - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,553
