跳转到主内容
Novatel MiFi 2200 Battery Replacement
你所需要的
  1. Novatel MiFi 2200 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Battery Replacement: 步骤 2 中的图像 1,1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Battery Replacement: 步骤 3 中的图像 1,1
    • Insert the new battery into the battery slot.
    • Make sure to place the battery in with the white arrows facing inward.
  4. Novatel MiFi 2200 Battery Replacement: 步骤 4 中的图像 1,2 Novatel MiFi 2200 Battery Replacement: 步骤 4 中的图像 2,2
    • Re-install the rear cover by placing the inward end in it's slot.
    • Push down on the cover while sliding it into the slot to snap it back into place.
结论
Charge your new battery and you are ready to use your Mifi again.
另外一个人完成了本指南。
Carissah
于04/15/12注册
147 声望
创作了2篇指南
团队
Cal Poly, Team 7-36, Maness Spring 2012 Cal Poly, Team 7-36, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G36
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 1,045
