跳转到主内容
Nostalgia GCM200 Power Cable Replacement
你所需要的
  1. Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: 步骤 1 中的图像 1,2 Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: 步骤 1 中的图像 2,2
    • Remove the two 1.3 mm Phillips #2 screws.
    • Remove the S6 spanner screw.
    • Carefully place these three screws somewhere safe to use later in reassembly.
  2. Nostalgia GCM200 Power Cable Replacement: 步骤 2 中的图像 1,1
    • Split the device in half to expose the internal parts of the device.
    • Again, there are two more Phillips screws to remove.
  3. Nostalgia GCM200 Power Cable Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws from both sides of the heating coil.
  4. Nostalgia GCM200 Power Cable Replacement, Power Cable: 步骤 4 中的图像 1,1
    • Remove (flexible) plastic sleeves from the inside end of the power cable.
    • You might want to use force, pull out while shaking it.
结论
另外一个人完成了本指南。
Praful Busa
于06/25/17注册
267 声望
创作了2篇指南
团队
UW Tacoma, Team S1-G4, Liner Summer 2017 UW Tacoma, Team S1-G4, Liner Summer 2017 的会员
UWT-LINER-SU17S1G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 12
总计 252
