简介
Follow the steps for replacing the power switch. This guide will start right after replacing power switch ends.
  1. Unplug popper.
    • Unplug popper.
    • Remove plastic lid by picking the lid up.
  2. Flip the popper on its side.
    • Flip the popper on its side.
    • Remove the screws on the bottom with the Phillips #2 phillips head screwdriver.
    • There are seven screws on the base. Five screws on the perimeter (12mm Philips #2 screws) and two in the middle (15 mm Philips #2 screws).
  3. Remove the base.
    • Remove the base.
    • Save the screws you took out of the bottom in a safe place. They will be needed to reattach the housing to the base.
    • Unscrew the two screws (10 mm Philips #2 screws) from the base.
    • Remove the base and set it aside for now.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Locate the power switch connected to the side of the housing. Carefully pinch the sides of the power switch.
    • Locate the power switch connected to the side of the housing.
    • Carefully pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  6. Now that the power switch is removed from the housing, you have to remove the wires connected to the power switch.
    • Now that the power switch is removed from the housing, you have to remove the wires connected to the power switch.
    • Use the plastic opening tool to gently pry the wires loose from the power switch.
    • The wires should pop easily out from the power switch.
  7. Remove the power switch from the device.
    • Remove the power switch from the device.
    • You can now replace the power switch if necessary.
  8. Now that the power switch is disconnected from the popper, you will need to remove the white top. Gently remove the heating component from the popper.
    • Now that the power switch is disconnected from the popper, you will need to remove the white top.
    • Gently remove the heating component from the popper.
    • Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
  9. Remove the white top from the housing.
    • Remove the white top from the housing.
    • Save the screws from previous step. You will need them to connect the new housing to the white top.
结论
Dana Clarke
于2012年09月26日注册
26 信誉积分
创作了6篇指南
团队
Cal Poly, Team 16-57, Forte Fall 2012 Cal Poly, Team 16-57, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G57
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 347
