简介
This guide will describe the maintenance of the device.
  1. Unplug popper.
    • Unplug popper.
    • Remove plastic lid by picking the lid up.
  2. Flip the popper on its side.
    • Flip the popper on its side.
    • Remove the screws on the bottom with the Phillips #2 phillips head screwdriver.
    • There are seven screws on the base. Five screws on the perimeter (12mm Philips #2 screws) and two in the middle (15 mm Philips #2 screws).
    • Remove the base.
    • Save the screws you took out of the bottom in a safe place. They will be needed to reattach the housing to the base.
    • Unscrew the two screws (10 mm Philips #2 screws) from the base.
    • Remove the base and set it aside for now.
    • Locate the power switch connected to the side of the housing.
    • Carefully pinch the sides of the power switch.
    • Push the power button up and out of the housing.
    • Now that the power switch is removed from the housing, you have to remove the wires connected to the power switch.
    • Use the plastic opening tool to gently pry the wires loose from the power switch.
    • The wires should pop easily out from the power switch.
    • Remove the power switch from the device.
    • You can now replace the power switch if necessary.
    • Now that the power switch is disconnected from the popper, you will need to remove the white top.
    • Gently remove the heating component from the popper.
    • Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
    • Remove the white top from the housing.
    • Save the screws from previous step. You will need them to connect the new housing to the white top.
    • Now that the white top is disconnected from the housing, remove the heating component from inside the device.
    • Unscrew the three screws (10 mm Philips #2 screws) that hold the heating component together.
    • Make sure to keep the screws. You will need them to put the heating component back together.
    • Pull the heating component apart.
    • Locate the fan.
    • Pull the fan off the motor firmly but gently.
    • When you pull the fan off the motor, be careful. Do not pull to hard or you will break the motor.
    • You can now replace the fan.
    • If there is debris stuck in the fan, you can easily clean it out from the fan in this step.
    • Remove the heating coil out of the heating component.
    • Visually check for debris.
    • Remove debris.
结论
Dana Clarke
于2012年09月26日注册
26 信誉积分
创作了6篇指南
团队
Cal Poly, Team 16-57, Forte Fall 2012 Cal Poly, Team 16-57, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G57
5 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 3
过去的7天: 6
过去的30天: 15
总计 974
