跳转到主内容
Nostalgia Electrics PCM805 Motor Replacement
你所需要的
  1. Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: 步骤 1 中的图像 1,2 Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: 步骤 1 中的图像 2,2
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Motor Replacement: 步骤 2 中的图像 1,1
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: 步骤 3 中的图像 1,2 Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: 步骤 3 中的图像 2,2
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  4. Nostalgia Electrics PCM805 Motor Replacement: 步骤 4 中的图像 1,3 Nostalgia Electrics PCM805 Motor Replacement: 步骤 4 中的图像 2,3 Nostalgia Electrics PCM805 Motor Replacement: 步骤 4 中的图像 3,3
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  5. Nostalgia Electrics PCM805 Motor Replacement, Motor: 步骤 5 中的图像 1,2 Nostalgia Electrics PCM805 Motor Replacement, Motor: 步骤 5 中的图像 2,2
    • Remove the four 12mm Phillips #02 screws to free the motor housing.
  6. Nostalgia Electrics PCM805 Motor Replacement: 步骤 6 中的图像 1,2 Nostalgia Electrics PCM805 Motor Replacement: 步骤 6 中的图像 2,2
    • Line up the prongs on the motor shaft with the holes in the heating element and pull the motor out.
结论
Joshua Harriger
于01/13/15注册
309 声望
创作了2篇指南
团队
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 的会员
USFT-HICKMAN-W15S3G5
5 名成员
创作了8篇指南
2指南评论
Hello.
I purchased this item in a red variation from VAT19. It does not work but the light comes on. I live in the UK and we have a higher Voltage(240V) running in our domestic supply.
Something may have blown.
Can you advise what is it likely to be?
If there is a part that we can replace, can you advise which one and where I can purchase it from please?
Moh - 回复
Hi, I need the cotton machine from the nostalgia cotton sugar machine and I don't know where to get it. can you help me? My email is terebcn18@hotmail.com
Teresa gb - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 3,437
