跳转到主内容
Nostalgia Electrics PCM805 Heating Element
你所需要的
  1. Nostalgia Electrics PCM805 Heating Element, Bowl: 步骤 1 中的图像 1,1
    • Make sure that the device is unplugged and has not been used recently because the extractor head and bowl can be very hot.
    • Place the device on a steady table.
    • Lift and remove the rim.
  2. Nostalgia Electrics PCM805 Heating Element: 步骤 2 中的图像 1,3 Nostalgia Electrics PCM805 Heating Element: 步骤 2 中的图像 2,3 Nostalgia Electrics PCM805 Heating Element: 步骤 2 中的图像 3,3
    • Twist the bowl clockwise until it is free of the groove and lift to remove.
  3. Nostalgia Electrics PCM805 Heating Element, Extractor Head: 步骤 3 中的图像 1,2 Nostalgia Electrics PCM805 Heating Element, Extractor Head: 步骤 3 中的图像 2,2
    • Firmly grip the extractor head and slowly lift vertically to remove from the device.
    I need the extractor piece for my machine. Can I get it
    sungiddess196626 - 回复
  4. Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: 步骤 4 中的图像 1,2 Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: 步骤 4 中的图像 2,2
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  5. Nostalgia Electrics PCM805 Heating Element: 步骤 5 中的图像 1,1
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  6. Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: 步骤 6 中的图像 1,2 Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: 步骤 6 中的图像 2,2
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  7. Nostalgia Electrics PCM805 Heating Element: 步骤 7 中的图像 1,3 Nostalgia Electrics PCM805 Heating Element: 步骤 7 中的图像 2,3 Nostalgia Electrics PCM805 Heating Element: 步骤 7 中的图像 3,3
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  8. Nostalgia Electrics PCM805 Heating Element, Heating Element: 步骤 8 中的图像 1,2 Nostalgia Electrics PCM805 Heating Element, Heating Element: 步骤 8 中的图像 2,2
    • Remove the six 10mm Phillips #02 screws that secure the metal housing covering the heating element.
    • Remove the metal housing.
  9. Nostalgia Electrics PCM805 Heating Element: 步骤 9 中的图像 1,2 Nostalgia Electrics PCM805 Heating Element: 步骤 9 中的图像 2,2
    • Remove the four 9mm Phillips #02 screws that secure the heating element to the rest of the device.
  10. Nostalgia Electrics PCM805 Heating Element: 步骤 10 中的图像 1,2 Nostalgia Electrics PCM805 Heating Element: 步骤 10 中的图像 2,2
    • Line up the prongs on the motor shaft with the slots in either side of the hole in the heating element and lift it off the device.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 的会员
USFT-HICKMAN-W15S3G5
5 名成员
创作了8篇指南
一条评论
Where can I buy a replacement heating element?
Eric P. Rose - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 5,370
