跳转到主内容
Nook Tablet Speaker Assembly Replacement
你所需要的
  1. Nook Tablet Speaker Assembly Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Flip the Nook over.
  2. Nook Tablet Speaker Assembly Replacement: 步骤 2 中的图像 1,2 Nook Tablet Speaker Assembly Replacement: 步骤 2 中的图像 2,2
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
  3. Nook Tablet Speaker Assembly Replacement: 步骤 3 中的图像 1,2 Nook Tablet Speaker Assembly Replacement: 步骤 3 中的图像 2,2
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Nook Tablet Speaker Assembly Replacement: 步骤 4 中的图像 1,2 Nook Tablet Speaker Assembly Replacement: 步骤 4 中的图像 2,2
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Nook Tablet Speaker Assembly Replacement: 步骤 5 中的图像 1,1
    • Pull the back panel off the Nook.
  6. Nook Tablet Speaker Assembly Replacement, Screen Bezel: 步骤 6 中的图像 1,2 Nook Tablet Speaker Assembly Replacement, Screen Bezel: 步骤 6 中的图像 2,2
    • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
  7. Nook Tablet Speaker Assembly Replacement: 步骤 7 中的图像 1,2 Nook Tablet Speaker Assembly Replacement: 步骤 7 中的图像 2,2
    • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  8. Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: 步骤 8 中的图像 1,2 Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: 步骤 8 中的图像 2,2
    • Lift up the foam pad at the corner of the battery to reveal the battery connector.
    • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
  9. Nook Tablet Speaker Assembly Replacement, Midframe: 步骤 9 中的图像 1,1
    • Lift up the foam that covers the power connector and volume connector.
    • Disconnect the power and volume cables from their sockets on the motherboard.
  10. Nook Tablet Speaker Assembly Replacement: 步骤 10 中的图像 1,2 Nook Tablet Speaker Assembly Replacement: 步骤 10 中的图像 2,2
    • Carefully lift the silver midframe away from the motherboard and display assembly.
    • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
  11. Nook Tablet Speaker Assembly Replacement, Removing Speaker Assembly: 步骤 11 中的图像 1,1
    • Using your hands pull the square speaker assembly component off the motherboard.
  12. Nook Tablet Speaker Assembly Replacement, Replacing Speaker Assembly: 步骤 12 中的图像 1,1
    • Now place the new speaker assembly component back in the same square location.
    • As Step 12 mentions, make sure to realign the speaker assembly correctly in the square.
结论
另外一个人完成了本指南。
Josh Fisher
于09/26/12注册
9 声望
撰写一个指南
团队
Cal Poly, Team 1-4, Propen Fall 2012 Cal Poly, Team 1-4, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G4
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 2,226
