跳转到主内容
Nook HD+ Top Frame Replacement
你所需要的
  1. Nook HD+ Top Frame Replacement, Removing Top Frame: 步骤 1 中的图像 1,3 Nook HD+ Top Frame Replacement, Removing Top Frame: 步骤 1 中的图像 2,3 Nook HD+ Top Frame Replacement, Removing Top Frame: 步骤 1 中的图像 3,3
    • Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame.
    • Note there will be glue and be careful not to break the clips.
  2. Nook HD+ Top Frame Replacement, Add New Glue: 步骤 2 中的图像 1,1
    • Apply glue round the inside perimeter of the new frame on the clip side.
  3. Nook HD+ Top Frame Replacement: 步骤 3 中的图像 1,1
    • Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
    • Run finger around the entire frame making sure all the clips are in place.
    • Let glue dry.
结论
Alex Pelicas
于10/17/14注册
283 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S2G3
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 819
