跳转到主内容
加入维修社区 - 创建账户
Nook HD+ Motherboard Replacement
你所需要的
  1. Nook HD+ Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Nook HD+ Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Nook HD+ Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
    • Pop up all plastic tabs that secure the frame to the chassis.
  2. Nook HD+ Motherboard Replacement: 步骤 2 中的图像 1,3 Nook HD+ Motherboard Replacement: 步骤 2 中的图像 2,3 Nook HD+ Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing using a screwdriver.
    • Disconnect battery from motherboard.
    • Remove back casing.
  3. Nook HD+ Motherboard Replacement: 步骤 3 中的图像 1,2 Nook HD+ Motherboard Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
    • Use tweezers to lift the flaps.
  4. Nook HD+ Motherboard Replacement: 步骤 4 中的图像 1,1
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the motherboard.
    • No tool is needed. Gently pull on the wires until the piece disconnects.
  5. Nook HD+ Motherboard Replacement: 步骤 5 中的图像 1,1
    • Disconnect antenna from motherboard by pulling up with slight force.
  6. Nook HD+ Motherboard Replacement: 步骤 6 中的图像 1,2 Nook HD+ Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove two 5.0 mm Torx T5 screws attached to the motherboard using a screwdriver.
    • Lift the small foam piece attached to the black strip on the motherboard and gently pull up.
  7. Nook HD+ Motherboard Replacement: 步骤 7 中的图像 1,2 Nook HD+ Motherboard Replacement: 步骤 7 中的图像 2,2
    • With the black strip lifted, carefully snap the motherboard out of the plastic pieces holding it down.
    • Remove the motherboard.
结论
Brennan Holcombe
于03/31/22注册
256 声望
创作了2篇指南
团队
IUPUI, Team 3-3, Harley Spring 2022 IUPUI, Team 3-3, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S3G3
3 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 384
