跳转到主内容
Nook HD+ Speaker Replacement
你所需要的
  1. Nook HD+ Speaker Replacement, Take off the Top Frame: 步骤 1 中的图像 1,1
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
    • Pry open the front frame.
  2. Nook HD+ Speaker Replacement, Remove the screws: 步骤 2 中的图像 1,2 Nook HD+ Speaker Replacement, Remove the screws: 步骤 2 中的图像 2,2
    • Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
  3. Nook HD+ Speaker Replacement, Remove the Battery: 步骤 3 中的图像 1,2 Nook HD+ Speaker Replacement, Remove the Battery: 步骤 3 中的图像 2,2
    • Carefully remove the bottom frame from center chassis.
    • Detach the battery ribbon from the motherboard.
    • Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
  4. Nook HD+ Speaker Replacement, Unscrew the speaker: 步骤 4 中的图像 1,1
    • In the bottom left hand corner remove the 3 screws that at attached to the speaker
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
    • Replace old speaker with new speaker then follow instructions in reverse order to reassemble
结论
2等其他人完成本指南。
Alex Pelicas
于10/17/14注册
283 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S2G3
5 名成员
创作了10篇指南
一条评论
After purchasing a replacement speaker, these steps worked well. Process to a fairly relaxed 20 minutes.
The only thing I’d add is that the speaker is part # AAC121217U22A, and appears to be a bespoke part containing two speakers.
Knowing what part to look for may help others looking for a replacement part.
Jamal Taylor - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 729
