跳转到主内容
Nook HD+ Battery Replacement
你所需要的
  1. Nook HD+ Battery Replacement, Remove the front frame: 步骤 1 中的图像 1,3 Nook HD+ Battery Replacement, Remove the front frame: 步骤 1 中的图像 2,3 Nook HD+ Battery Replacement, Remove the front frame: 步骤 1 中的图像 3,3
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Nook HD+ Battery Replacement, Remove the screws: 步骤 2 中的图像 1,2 Nook HD+ Battery Replacement, Remove the screws: 步骤 2 中的图像 2,2
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Battery Replacement, Remove the chassis: 步骤 3 中的图像 1,1
    • Carefully remove center chassis from bottom frame.
  4. Nook HD+ Battery Replacement, Detach battery: 步骤 4 中的图像 1,3 Nook HD+ Battery Replacement, Detach battery: 步骤 4 中的图像 2,3 Nook HD+ Battery Replacement, Detach battery: 步骤 4 中的图像 3,3
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Battery Replacement, Remove the battery: 步骤 5 中的图像 1,2 Nook HD+ Battery Replacement, Remove the battery: 步骤 5 中的图像 2,2
    • Pry battery off of bottom frame using plastic opening tool.
  6. Nook HD+ Battery Replacement, Place new battery: 步骤 6 中的图像 1,1
    • Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
结论
12等其他人完成本指南。
Elijah Gonsalves
于10/24/14注册
1,049 声望
创作了3篇指南
团队
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S2G3
5 名成员
创作了10篇指南
5条评论
Does model affect battery type? The replacement battery was stated so I'm just curious
Jon - 回复
Where i can buy new battery, or any similar [6000 mAh] ?
Sebastian kukosh - 回复
Anyone have a lead on good batteries?
omarhani - 回复
clear directions, liked this guide
wandat100 - 回复
i have a Barnes and noble nook HD+ and how it won't charger at all.
Tina Brown - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 51
总计 9,470
