跳转到主内容
Nook Color Speaker Replacement
John Goly
John Goly3 其他贡献者
最后更新于 June 12, 2019
5 - 10 分钟
中等
需要更多图片
缺少的步骤
步骤精简
This guide will provide in depth steps in the replacement of a damaged or faulty speaker. When removing the speaker from your device some force will be necessary in their separation.
你所需要的
工具
查看更多...
  1. Nook Color Speaker Replacement, Back Cover: 步骤 1 中的图像 1,2 Nook Color Speaker Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
  2. Nook Color Speaker Replacement: 步骤 2 中的图像 1,2 Nook Color Speaker Replacement: 步骤 2 中的图像 2,2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
  3. Nook Color Speaker Replacement, Front Cover: 步骤 3 中的图像 1,1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
  4. Nook Color Speaker Replacement: 步骤 4 中的图像 1,2 Nook Color Speaker Replacement: 步骤 4 中的图像 2,2
    • Pry off the front panel using the plastic opening tool.
  5. Nook Color Speaker Replacement: 步骤 5 中的图像 1,2 Nook Color Speaker Replacement: 步骤 5 中的图像 2,2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
  6. Nook Color Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 Nook Color Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    • Remove the protective lining located above the speaker.
  7. Nook Color Speaker Replacement: 步骤 7 中的图像 1,3 Nook Color Speaker Replacement: 步骤 7 中的图像 2,3 Nook Color Speaker Replacement: 步骤 7 中的图像 3,3
    • Using a plastic opening tool, push on the speaker from the front of the panel to loosen the speaker. Some force will be required. Once loose, use your index finger to push it through.
  8. Nook Color Speaker Replacement: 步骤 8 中的图像 1,1
    • Once pressed all the way through, the speaker will be loose and free to replace.
结论
John Goly
于01/20/15注册
508 声望
创作了3篇指南
团队
USF Tampa, Team 11-5, Blackwell Winter 2015 USF Tampa, Team 11-5, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G5
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 24
总计 322
