跳转到主内容
加入维修社区 - 创建账户
Nook Color Motherboard Replacement
你所需要的
  1. Nook Color Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Nook Color Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
  2. Nook Color Motherboard Replacement: 步骤 2 中的图像 1,2 Nook Color Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
  3. Nook Color Motherboard Replacement, Front Cover: 步骤 3 中的图像 1,1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
  4. Nook Color Motherboard Replacement: 步骤 4 中的图像 1,2 Nook Color Motherboard Replacement: 步骤 4 中的图像 2,2
    • Pry off the front panel using the plastic opening tool.
  5. Nook Color Motherboard Replacement: 步骤 5 中的图像 1,2 Nook Color Motherboard Replacement: 步骤 5 中的图像 2,2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
  6. Nook Color Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 Nook Color Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 Nook Color Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
  7. Nook Color Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
  8. Nook Color Motherboard Replacement: 步骤 8 中的图像 1,2 Nook Color Motherboard Replacement: 步骤 8 中的图像 2,2
    • Lift the motherboard gently from the side with the larger connector ribbon.
    • Slide the white cable gently from underneath its holding place to free the motherboard completely.
    • Remove the motherboard carefully from the device.
结论
2等其他人完成本指南。
Matthew Perdomo
于01/20/15注册
509 声望
创作了3篇指南
团队
USF Tampa, Team 11-5, Blackwell Winter 2015 USF Tampa, Team 11-5, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G5
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 1,248
