跳转到主内容
Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement
你所需要的
  1. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Back Cover Removal: 步骤 1 中的图像 1,1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Battery Removal: 步骤 2 中的图像 1,2 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Battery Removal: 步骤 2 中的图像 2,2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 1: 步骤 3 中的图像 1,2 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 1: 步骤 3 中的图像 2,2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: 步骤 4 中的图像 1,3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: 步骤 4 中的图像 2,3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, System components: 步骤 5 中的图像 1,1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: 步骤 6 中的图像 1,3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: 步骤 6 中的图像 2,3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Gently unsnap the 3 motherboard connectors for the touch screen assembly with tweezers.
    • The touch screen, volume buttons, and power/screen lock button assembly can now be removed.
结论
16等其他人完成本指南。
团队
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014 的会员
USFT-BROWN-F14S1G4
3 名成员
创作了7篇指南
一条评论
next pic i whant this information touch change....
prakash prakash - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 16,034
