简介
This replacement guide will save you from having to buy a new phone by showing you how to replace the touch screen, volume buttons, and power/screen lock button assembly of your Nokia XL Dual SIM Android Smartphone.
你所需要的
You will first need to separate the back cover from the device.
Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
Remove the back cover.
Use a plastic opening tool to lift the battery. Then, remove it.
To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
The locations of the T5x3.4mm screws are indicated in the picture.
The locations of the T5x4.1mm screws are indicated in the picture.
Use the plastic opening tool to gently pry the device apart.
There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
在这个步骤中使用的工具:Tweezers$4.99
Gently unsnap the 3 motherboard connectors for the touch screen assembly with tweezers.
The touch screen, volume buttons, and power/screen lock button assembly can now be removed.
16等其他人完成本指南。
