跳转到主内容
Nokia X USB Port Replacement
你所需要的
  1. Nokia X USB Port Replacement, Nokia X Disassembly Prerequisites: 步骤 1 中的图像 1,1
    • Remove the back cover of the device by applying light pressure toward the outer rim and display.
  2. Nokia X USB Port Replacement: 步骤 2 中的图像 1,1
    • Remove 7 (size 4 M1 4*3.5) and 4(size 6 M2 6*4.5) screws using P5 hex screwdriver.
    • The M2 screws are shown in red.
    • The M1 screws are shown in orange.
  3. Nokia X USB Port Replacement: 步骤 3 中的图像 1,1
    • Gently separate the display from the chassis.
    • Slowly spread the display and chassis until the inside of the device is reachable.
    • Do not pull apart.
  4. Nokia X USB Port Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Spudger
    $2.99
    • Using the spudger tool, release the top flex ribbon from the light swap package.
  5. Nokia X USB Port Replacement, USB Port: 步骤 5 中的图像 1,2 Nokia X USB Port Replacement, USB Port: 步骤 5 中的图像 2,2
    • Again, using a spudger tool, release the rear facing camera from the light swap display.
    • Carefully remove the light swap display from the chassis by applying pressure to the circuit board.
  6. Nokia X USB Port Replacement: 步骤 6 中的图像 1,1
    • Using a soldering iron, desolder they broken USB port.
    • Solder your replacement USB port onto the light swap package.
结论
6等其他人完成本指南。
Josh Perino
于03/04/17注册
436 声望
创作了2篇指南
团队
IUPUI, Team S7-G7, Wilson Spring 2017 IUPUI, Team S7-G7, Wilson Spring 2017 的会员
IUPUI-WILSON-S17S7G7
3 名成员
创作了8篇指南
1指南评论
my mobile usb port no pls replacement
Giri GOWDA Nature RIDER - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 1,464
