跳转到主内容
Nokia X Display Assembly Replacement
你所需要的
  1. Nokia X Display Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
  2. Nokia X Display Assembly Replacement: 步骤 2 中的图像 1,1
    • To remove the battery, simply use your finger to pry the battery out of its slot.
  3. Nokia X Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
  4. Nokia X Display Assembly Replacement, Display Assembly: 步骤 4 中的图像 1,2 Nokia X Display Assembly Replacement, Display Assembly: 步骤 4 中的图像 2,2
    • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
    • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
  5. Nokia X Display Assembly Replacement: 步骤 5 中的图像 1,2 Nokia X Display Assembly Replacement: 步骤 5 中的图像 2,2
    • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
  6. Nokia X Display Assembly Replacement: 步骤 6 中的图像 1,1
    • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
结论
29等其他人完成本指南。
Avery Dorsey
于01/21/15注册
1,894 声望
创作了4篇指南
团队
USF Tampa, Team 6-1, Brown Winter 2015 USF Tampa, Team 6-1, Brown Winter 2015 的会员
USFT-BROWN-W15S6G1
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 21
总计 5,552
