你所需要的
这个步骤还没有翻译 帮忙翻译一下
Our latest victim -- Nokia's just-released N8.
Technical specs:
ARM11 680 MHz processor
640 × 360 (nHD), 3.5" capacitive, multi-touch display with AMOLED technology
256 MB SDRAM
512 MB internal NAND memory and 16 GB on-board memory
12 Megapixels (main) with Carl Zeiss optics and Xenon flash, 16:9 720p video, 25 FPS
这个步骤还没有翻译 帮忙翻译一下
The 12 MP auto-focus camera is a honker. As we've seen in other smartphones, the thickness of the camera drives the thickness of the phone.
According to Dr. Hubert Nasse, the lens inside the camera module is composed of five individual aspherical shaped optical elements. This complex shape facilitates very high quality pictures out of a very small device.
Nokia chose to have the camera protrude outside of the back cover, which could either provide a good grasping point when taking the phone out of your pocket, or make it a hassle when returning the phone to your pocket.
这个步骤还没有翻译 帮忙翻译一下
Aside from a standard 3.5mm stereo headphone jack, the N8 features both a mini HDMI and a micro USB port. Not sure what to do with that HDMI port? Try setting a world record.
Buttons include: Power, Home, Hold, Camera, and Volume Switch.
The SIM and MicroSD ports are mounted side by side on the exterior of the phone, allowing for hot-swapping of the MicroSD.
这个步骤还没有翻译 帮忙翻译一下
Thankfully the glass is not fused to the face of the AMOLED display, so you don't have to replace both if just the glass breaks.
The silk screen on the back of the display reads:
AMS347FF01-0
The silk screen also indicates the display was manufactured February 2, 2010. This thing has been around for quite some time.
The touch screen controller is a Synaptics T1201A. This is the same chip found in the Microsoft Kin Two and RIM Blackberry Torch.
这个步骤还没有翻译 帮忙翻译一下
After the mid-plane is removed, the motherboard can be simply lifted out of the rear case.
The daughter board at the top of the motherboard has an interesting design in that it is connected to the main motherboard via a ribbon cable that is sandwiched between the many layers of the motherboard.
这个步骤还没有翻译 帮忙翻译一下
The Nokia N8 motherboard:
Toshiba THGBM1G7D4FBA13 K23538 (16 GB Internal Memory)
Samsung K5W4G2GACA - AL54 (CPU + DDR RAM + NAND ROM)
Broadcom BCM2727 GPU with dedicated 3D Graphics
4380044 9920Q VJ (RF Transceiver) from STMicroelectronics
EPCOS D1053 (RF Front end module)
RENESAS 09801A (RF Power amplifier)
4376057 GAZ0035G (Baseband) from Texas Instruments
这个步骤还没有翻译 帮忙翻译一下
With the motherboard out of the rear case, the flash unit simply lifts out.
As opposed to many other smartphones that use either a single or double LED for the flash, the N8 uses a Xenon flash tube similar to the kind of flash found in full-size cameras.
The large capacitor on the flash module supplies the high voltage necessary to produce such a brilliant flash.
这个步骤还没有翻译 帮忙翻译一下
Nokia N8 Repairability: 8 out of 10 (10 is easiest to repair)
The battery, although considered by Nokia not to be user-serviceable, can be easily removed.
The AMOLED display easily comes apart from the glass, which means that you can replace the glass and the display independently.
There are mostly mechanical fasteners, and very little glue inside.
You still have to use a heat gun to remove the front glass, but at least you're heating up metal that won't deform as easily as plastic.
Removing the cameras is near-impossible, and requires tedious, potentially detrimental steps.
6条评论
I love the way they've managed to hide an iphone screen cover in the n8 (step 11!) Nice touch!
………….….joke?
