跳转到主内容
Nokia N900 USB Replacement
你所需要的
  1. Nokia N900 USB Replacement, USB: 步骤 1 中的图像 1,1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 USB Replacement: 步骤 2 中的图像 1,2 Nokia N900 USB Replacement: 步骤 2 中的图像 2,2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 USB Replacement: 步骤 3 中的图像 1,1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 USB Replacement: 步骤 4 中的图像 1,2 Nokia N900 USB Replacement: 步骤 4 中的图像 2,2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 USB Replacement: 步骤 5 中的图像 1,1
    • You will now have two halves of the phone.
    • Grab the half of the phone that has the keyboard on it
  6. Nokia N900 USB Replacement: 步骤 6 中的图像 1,1
    • Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
    • Place the key pad and cover to the side for the remaining steps.
  7. Nokia N900 USB Replacement: 步骤 7 中的图像 1,1
    • Use a blue plastic opening tool lift the motherboard out of the back cover
  8. Nokia N900 USB Replacement: 步骤 8 中的图像 1,1
    • Look at the bottom of the motherboard to find the:
    • USB Port
    • Once you've located the USB Port you can search online or call the manufacturer to replace it.
结论
3等其他人完成本指南。
Troy Posey
于03/13/14注册
349 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 16
总计 2,581
