跳转到主内容
Nokia N900 Slider Assembly Replacement
你所需要的
  1. Nokia N900 Slider Assembly Replacement, Slider Assembly: 步骤 1 中的图像 1,1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 Slider Assembly Replacement: 步骤 2 中的图像 1,2 Nokia N900 Slider Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 Slider Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 Slider Assembly Replacement: 步骤 4 中的图像 1,2 Nokia N900 Slider Assembly Replacement: 步骤 4 中的图像 2,2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 Slider Assembly Replacement: 步骤 5 中的图像 1,1
    • Turn the back of the phone over so the keyboard is face up. You should then have two halves of the phone.
    • To locate the slider, find the "black tape" on the screen half of the phone.
    • Weave the "slider tape" through the orange slot on the keyboard half of the phone.
    • Once you have completed these steps your phone should be able to slide up and down with ease.
结论
另外一个人完成了本指南。
Troy Posey
于03/13/14注册
349 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 835
