跳转到主内容
修复你的物品
维修的权力
商店
简介
After following this guide, you can replace the battery of the Nokia N9.
  1. Click open the USB input protector lid and pull it from the housing. Also remove the SIM card holder. Remove screws from the top.
    • Click open the USB input protector lid and pull it from the housing.
    • Also remove the SIM card holder.
    • Remove screws from the top.
  2. Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone. Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone. Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone.
    • Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone.
  3. Using a plastic tool, carefully open up the distance between the screen and the housing until the screen is only attached with 2 cables. With the same plastic tool, disconnect the screen cables still attached to the phone. The screen is now separated from the rest of the phone.
    • Using a plastic tool, carefully open up the distance between the screen and the housing until the screen is only attached with 2 cables.
    • With the same plastic tool, disconnect the screen cables still attached to the phone.
    • The screen is now separated from the rest of the phone.
  4. Unscrew the marked screws.
    • Unscrew the marked screws.
  5. You will see a strip holding the larger battery cover in place at one side. Rotate the strip a quarter turn along the long axis, and lift it out.
    • You will see a strip holding the larger battery cover in place at one side.
    • Rotate the strip a quarter turn along the long axis, and lift it out.
    • Use the opening tool to lift the battery cover up and out.
  6. Click open the battery connector from beneath the connector. Lift the battery from the phone and replace it.
    • Click open the battery connector from beneath the connector.
    • Lift the battery from the phone and replace it.
结论
2等其他人完成本指南。
knipwim
于2018年09月01日注册
2,498 信誉积分
创作了20篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 7
过去的30天: 35
总计 1,084
