跳转到主内容
Nokia N70 Keypad Replacement
你所需要的
  1. Nokia N70 Keypad Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Keypad Replacement: 步骤 2 中的图像 1,1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Keypad Replacement: 步骤 3 中的图像 1,1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Keypad Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from the phone.
  5. Nokia N70 Keypad Replacement, Keypad: 步骤 5 中的图像 1,3 Nokia N70 Keypad Replacement, Keypad: 步骤 5 中的图像 2,3 Nokia N70 Keypad Replacement, Keypad: 步骤 5 中的图像 3,3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Keypad Replacement: 步骤 6 中的图像 1,3 Nokia N70 Keypad Replacement: 步骤 6 中的图像 2,3 Nokia N70 Keypad Replacement: 步骤 6 中的图像 3,3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
结论
Justin
于10/12/11注册
984 声望
创作了5篇指南
团队
Cal Poly, Team 6-2, Regan Fall 2011 Cal Poly, Team 6-2, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G2
4 名成员
创作了10篇指南
一条评论
I have N70 nokia mobile. Its keypad buttons 1, 2 & C and also left key and upper key is not working
please give me solution how to solve this problem
Imamuddin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 4,006
