跳转到主内容
修复你的物品
维修的权力
配件 & 工具
配件
没有特定配件。
  1. Orient the phone as shown.
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Remove the battery cover by lifting it away from the phone.
    • Remove the battery cover by lifting it away from the phone.
  3. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  4. Insert the plastic opening tool into the marked space.
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  5. Remove the battery from the phone.
    • Remove the battery from the phone.
  6. Insert the plastic opening tool in the marked areas in between the front and back covers. Pry each corner with the plastic opening tool until the front case completely detaches. Pry each corner with the plastic opening tool until the front case completely detaches.
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  7. Orient the phone so that the keypad is facing you. Remove the keypad by lifting it away from the phone. Remove the keypad by lifting it away from the phone.
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
结论
Justin
于2011年10月12日注册
960 信誉积分
创作了5篇指南
团队
Cal Poly, Team 6-2, Regan Fall 2011 Cal Poly, Team 6-2, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G2
4 名成员
创作了10篇指南
I have N70 nokia mobile. Its keypad buttons 1, 2 & C and also left key and upper key is not working
please give me solution how to solve this problem
Imamuddin - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 4
总计 3,653
