跳转到主内容
Nokia N-gage Nem-4 Housing Replacement
  1. Nokia N-gage Nem-4 Housing Replacement, Housing: 步骤 1 中的图像 1,3 Nokia N-gage Nem-4 Housing Replacement, Housing: 步骤 1 中的图像 2,3 Nokia N-gage Nem-4 Housing Replacement, Housing: 步骤 1 中的图像 3,3
    • To take off the housing you need to turn the device upside down and push the release button down at the bottom of the phone and pull the cover down with your thumbs until you hear a click, and the cover should come free
  2. Nokia N-gage Nem-4 Housing Replacement, Undoing clips and lifting off bezel: 步骤 2 中的图像 1,3 Nokia N-gage Nem-4 Housing Replacement, Undoing clips and lifting off bezel: 步骤 2 中的图像 2,3 Nokia N-gage Nem-4 Housing Replacement, Undoing clips and lifting off bezel: 步骤 2 中的图像 3,3
    • To take off the front bezel you need to put your nails under the clips pictured and pry off the case
  3. Nokia N-gage Nem-4 Housing Replacement, Lifting off bezel: 步骤 3 中的图像 1,3 Nokia N-gage Nem-4 Housing Replacement, Lifting off bezel: 步骤 3 中的图像 2,3 Nokia N-gage Nem-4 Housing Replacement, Lifting off bezel: 步骤 3 中的图像 3,3
    • With the housing unclipped you should be able to lift it off.
  4. Nokia N-gage Nem-4 Housing Replacement, Removing button pads: 步骤 4 中的图像 1,2 Nokia N-gage Nem-4 Housing Replacement, Removing button pads: 步骤 4 中的图像 2,2
    • Lift off the buttons to reveal a bare contact pad. Now you have removed the housing !
结论
另外一个人完成了本指南。
ethancross2001
于04/13/15注册
1 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 823
