跳转到主内容
Nokia Lumia 930 Motherboard Replacement
你所需要的
  1. Nokia Lumia 930 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Pull the SIM card holder out of the top of the phone using your fingernail.
  2. Nokia Lumia 930 Motherboard Replacement: 步骤 2 中的图像 1,2 Nokia Lumia 930 Motherboard Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
  3. Nokia Lumia 930 Motherboard Replacement: 步骤 3 中的图像 1,2 Nokia Lumia 930 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
  4. Nokia Lumia 930 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the 4mm Torx #4 screw that's securing the battery connector.
  5. Nokia Lumia 930 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use tweezers to remove the battery connector strap.
  6. Nokia Lumia 930 Motherboard Replacement: 步骤 6 中的图像 1,2 Nokia Lumia 930 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
  7. Nokia Lumia 930 Motherboard Replacement: 步骤 7 中的图像 1,3 Nokia Lumia 930 Motherboard Replacement: 步骤 7 中的图像 2,3 Nokia Lumia 930 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Use the flat end of a spudger to pry the battery cover from the phone's frame.
  8. Nokia Lumia 930 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Pull up on the heat spreader.
    • Be careful not to tear it!
  9. Nokia Lumia 930 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Use the flat end of the spudger to lift up the battery.
    • The battery is glued in place. Pry up carefully, not to damage it.
    • Two flex cables are directly underneath the battery.
  10. Nokia Lumia 930 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the battery from the phone.
  11. Nokia Lumia 930 Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,2 Nokia Lumia 930 Motherboard Replacement, Motherboard: 步骤 11 中的图像 2,2
    • Use the flat end of a spudger to disconnect the camera connectors.
    • Pull the camera up and out to remove it from the phone.
  12. Nokia Lumia 930 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
  13. Nokia Lumia 930 Motherboard Replacement: 步骤 13 中的图像 1,3 Nokia Lumia 930 Motherboard Replacement: 步骤 13 中的图像 2,3 Nokia Lumia 930 Motherboard Replacement: 步骤 13 中的图像 3,3
    • Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
    • Remove the orange flex cable from the phone.
  14. Nokia Lumia 930 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Repeat the previous step for the black jumper flex cable under the battery.
  15. Nokia Lumia 930 Motherboard Replacement: 步骤 15 中的图像 1,2 Nokia Lumia 930 Motherboard Replacement: 步骤 15 中的图像 2,2
    • Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
    • Remove the antenna.
  16. Nokia Lumia 930 Motherboard Replacement: 步骤 16 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to grab the adhesive that is under the LTE flex cable and pull it outwards and towards the bottom end of the phone.
    • Apply new adhesive when reassembling the phone.
  17. Nokia Lumia 930 Motherboard Replacement: 步骤 17 中的图像 1,3 Nokia Lumia 930 Motherboard Replacement: 步骤 17 中的图像 2,3 Nokia Lumia 930 Motherboard Replacement: 步骤 17 中的图像 3,3
    • Use a spudger to pry up the bottom end of the motherboard, then pull it out.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 1,130
