简介
This very simple guide will teach you how to remove the back cover from your device without damaging it. It is a very quick and easy guide that can be performed by anyone. It involves removing 1 screw and releasing plastic clips inside the phone to remove the back cover.
工具
配件
没有特定配件。
Power down the phone.
There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
Remove the sim card tray on the top of the phone.
Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
Once all the clips are released, remove the back cover of the phone.
