跳转到主内容
Nokia Lumia 925 Speaker Replacement
你所需要的
  1. Nokia Lumia 925 Speaker Replacement, Motherboard: 步骤 1 中的图像 1,2 Nokia Lumia 925 Speaker Replacement, Motherboard: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
    • Pull out the holder until it is completely separate.
    • Something like a paperclip will work if there are no tweezers available.
  2. Nokia Lumia 925 Speaker Replacement: 步骤 2 中的图像 1,3 Nokia Lumia 925 Speaker Replacement: 步骤 2 中的图像 2,3 Nokia Lumia 925 Speaker Replacement: 步骤 2 中的图像 3,3
    • Slide a plastic opening tool under the back cover.
    • Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
    • Some pins are facing the opposite way from the others.
  3. Nokia Lumia 925 Speaker Replacement: 步骤 3 中的图像 1,3 Nokia Lumia 925 Speaker Replacement: 步骤 3 中的图像 2,3 Nokia Lumia 925 Speaker Replacement: 步骤 3 中的图像 3,3
    • Remove the 3 screws using the T7 Torx screwdriver.
    • Unclip the black tab connector.
  4. Nokia Lumia 925 Speaker Replacement: 步骤 4 中的图像 1,2 Nokia Lumia 925 Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the silver metal cover.
    • Be careful of the tape under the right square side of the panel. Using a spudger helps.
  5. Nokia Lumia 925 Speaker Replacement: 步骤 5 中的图像 1,3 Nokia Lumia 925 Speaker Replacement: 步骤 5 中的图像 2,3 Nokia Lumia 925 Speaker Replacement: 步骤 5 中的图像 3,3
    • Unclip the two orange tabs.
    • Remove the four silver screws using the T5 Torx screwdriver.
  6. Nokia Lumia 925 Speaker Replacement: 步骤 6 中的图像 1,2 Nokia Lumia 925 Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
  7. Nokia Lumia 925 Speaker Replacement, Display: 步骤 7 中的图像 1,2 Nokia Lumia 925 Speaker Replacement, Display: 步骤 7 中的图像 2,2
    • Push the screen from the inside of the phone.
    • Pull the screen off.
    • Slide the electronic strip through the small opening.
  8. Nokia Lumia 925 Speaker Replacement, Speaker: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Locate the grey speaker/camera cover.
    • Carefully remove the cover with either a pair of tweezers or your fingers.
  9. Nokia Lumia 925 Speaker Replacement: 步骤 9 中的图像 1,3 Nokia Lumia 925 Speaker Replacement: 步骤 9 中的图像 2,3 Nokia Lumia 925 Speaker Replacement: 步骤 9 中的图像 3,3
    • With a pair of tweezers, gently remove the orange colored tab closest to the speaker.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 243
