跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up. Pull out the holder until it is completely separate.
    • Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
    • Pull out the holder until it is completely separate.
    • Something like a paperclip will work if there are no tweezers available.
  2. Slide a plastic opening tool under the back cover. Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone. Some pins are facing the opposite way from the others.
    • Slide a plastic opening tool under the back cover.
    • Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
    • Some pins are facing the opposite way from the others.
  3. Remove the 3 screws using the T7 Torx screwdriver. Unclip the black tab connector. Unclip the black tab connector.
    • Remove the 3 screws using the T7 Torx screwdriver.
    • Unclip the black tab connector.
  4. Manta 螺丝刀工具包
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  5. Remove the silver metal cover. Remove the silver metal cover.
    • Remove the silver metal cover.
  6. Unclip the two orange tabs. Remove the four silver screws using the T5 Torx screwdriver. Remove the four silver screws using the T5 Torx screwdriver.
    • Unclip the two orange tabs.
    • Remove the four silver screws using the T5 Torx screwdriver.
  7. Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up. Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
    • Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
  8. Push the screen from the inside of the phone. Pull the screen off.
    • Push the screen from the inside of the phone.
    • Pull the screen off.
    • Slide the electronic strip through the small opening.
结论
2等其他人完成本指南。
Guillermo Lara
于2018年09月18日注册
391 信誉积分
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 7
总计 249
