跳转到主内容
Nokia Lumia 920 Back panel Replacement
你所需要的
  1. Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: 步骤 1 中的图像 1,3 Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: 步骤 1 中的图像 2,3 Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: 步骤 1 中的图像 3,3
    • Make sure the phone is off.
    • Use the T5 screwdriver to remove the two 8.6mm long screws, located at the bottom of the phone. (Head size is 2.5mm)
  2. Nokia Lumia 920 Back panel Replacement: 步骤 2 中的图像 1,2 Nokia Lumia 920 Back panel Replacement: 步骤 2 中的图像 2,2
    • Use the smallest Torx screwdriver or another small poking tool and push into the hole on the SIM card slot. The plastic SIM protective piece should pop out quite easily.
    • Put that plastic piece aside.
  3. Nokia Lumia 920 Back panel Replacement: 步骤 3 中的图像 1,2 Nokia Lumia 920 Back panel Replacement: 步骤 3 中的图像 2,2
    • Once both screws on the bottom are removed, and the plastic SIM protective piece is removed, gently push on the outside of the screen.
    • The screen should become separated using little force. And should like the pictures shown once complete.
  4. Nokia Lumia 920 Back panel Replacement: 步骤 4 中的图像 1,2 Nokia Lumia 920 Back panel Replacement: 步骤 4 中的图像 2,2
    • This step may be easier to remove the battery first, but it is not mandatory.
    • Place the spudger tool or flat plastic tool on top of the ribbon cable to avoid damaging it when prying up on the metal clip.
    • Use a plastic opening tool, or gently use a small metal flat-head screwdriver to pry up the metal clip. (It is recommended to use a plastic tool; However, if the opening tool does not work or fit into the small opening underneath the clip, use the flat-head.)
  5. Nokia Lumia 920 Back panel Replacement: 步骤 5 中的图像 1,2 Nokia Lumia 920 Back panel Replacement: 步骤 5 中的图像 2,2
    • Once the metal clip is removed, gently pry up on the ribbon cable connection, located underneath the metal clip you have just removed.
结论
14等其他人完成本指南。
Jonathan
于10/31/14注册
1,492 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-2, Miles Fall 2014 UMass Dartmouth, Team 4-2, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G2
2 名成员
创作了7篇指南
一条评论
useless - doesnt show detail
nick - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 9,515
