跳转到主内容
Nokia Lumia 900 Speaker Replacement
你所需要的
  1. Nokia Lumia 900 Speaker Replacement, Screen: 步骤 1 中的图像 1,2 Nokia Lumia 900 Speaker Replacement, Screen: 步骤 1 中的图像 2,2
    • Insert the pointed end of the spudger into the sim card port indicated by the picture. Then proceed to remove the sim card port entirely.
  2. Nokia Lumia 900 Speaker Replacement: 步骤 2 中的图像 1,2 Nokia Lumia 900 Speaker Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the small rod in the port indicated in the picture.
  3. Nokia Lumia 900 Speaker Replacement: 步骤 3 中的图像 1,2 Nokia Lumia 900 Speaker Replacement: 步骤 3 中的图像 2,2
    • Separate the screen from the motherboard by prying it open with the spudger along with pulling upwards with the suction cup.
  4. Nokia Lumia 900 Speaker Replacement: 步骤 4 中的图像 1,2 Nokia Lumia 900 Speaker Replacement: 步骤 4 中的图像 2,2
    • Gently pull apart the screen from the motherboard, with only the ribbons connected from the motherboard to the screen.
  5. Nokia Lumia 900 Speaker Replacement: 步骤 5 中的图像 1,1
    • Disconnect the No-fuss cables from the motherboard by gently prying them up using the flat end of the black stick spudger. Make sure not to bend or crease the cable.
    • Remove the screen.
  6. Nokia Lumia 900 Speaker Replacement, Front Camera: 步骤 6 中的图像 1,2 Nokia Lumia 900 Speaker Replacement, Front Camera: 步骤 6 中的图像 2,2
    • Use the iFixit iOpener or another heat source to gently heat the top left corner until the adhesive under the camera softens.
    • Use the plastic opening tools to carefully lift the front camera from the motherboard.
  7. Nokia Lumia 900 Speaker Replacement, Battery: 步骤 7 中的图像 1,2 Nokia Lumia 900 Speaker Replacement, Battery: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger to carefully disconnect the ribbon cable.
    • Make sure not to bend or crease the cable.
  8. Nokia Lumia 900 Speaker Replacement: 步骤 8 中的图像 1,2 Nokia Lumia 900 Speaker Replacement: 步骤 8 中的图像 2,2
    • Use the flat end of a spudger to remove the battery.
    • The battery may be glued down. This will be evident if the battery is difficult to lift. Use the iFixit iOpener to heat the back of the phone allowing the glue to heat and become more pliable before trying to lift the battery again. This may take several minutes.
  9. Nokia Lumia 900 Speaker Replacement, Speaker: 步骤 9 中的图像 1,2 Nokia Lumia 900 Speaker Replacement, Speaker: 步骤 9 中的图像 2,2
    • Use the plastic opening tool to lift the orange ribbon cable from the motherboard.
  10. Nokia Lumia 900 Speaker Replacement: 步骤 10 中的图像 1,2 Nokia Lumia 900 Speaker Replacement: 步骤 10 中的图像 2,2
    • Use the plastic opening tool to lift the motherboard out of the casing.
    • It is recommended that you wedge the opening tool in the crevice between the motherboard and casing in the top righthand corner of the device.
  11. Nokia Lumia 900 Speaker Replacement: 步骤 11 中的图像 1,1
    • Use the flat end of a spudger to lift the LED out of the casing.
  12. Nokia Lumia 900 Speaker Replacement: 步骤 12 中的图像 1,2 Nokia Lumia 900 Speaker Replacement: 步骤 12 中的图像 2,2
    • Use the flat end of a spudger to lift the metal backplate from the casing.
    • Be sure not to lose the buttons.
  13. Nokia Lumia 900 Speaker Replacement: 步骤 13 中的图像 1,2 Nokia Lumia 900 Speaker Replacement: 步骤 13 中的图像 2,2
    • Wedge the pointed end of the spudger into the gaps in the antenna housing and pull the antenna housing away from the casing walls.
  14. Nokia Lumia 900 Speaker Replacement: 步骤 14 中的图像 1,2 Nokia Lumia 900 Speaker Replacement: 步骤 14 中的图像 2,2
    • Insert the pointed end of the spudger into the hole and slide the speaker housing out from the casing.
结论
Kourtney Collier
于03/31/22注册
289 声望
创作了3篇指南
团队
IUPUI, Team 3-2, Harley Spring 2022 IUPUI, Team 3-2, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S3G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 114
