跳转到主内容
Nokia Lumia 900 Screen Replacement
你所需要的
  1. 注意:步骤 1 源自标记为进行中的 指南
    Nokia Lumia 900 Screen Replacement, Opening The Phone: 步骤 1 中的图像 1,2 Nokia Lumia 900 Screen Replacement, Opening The Phone: 步骤 1 中的图像 2,2
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Screen Replacement, Detaching Screen Connectors: 步骤 2 中的图像 1,1
    • Detach both ribbon connectors from the logic board.
    • Attach new screen connectors to logic board
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
结论
3等其他人完成本指南。
Joshua Crosman
于10/20/14注册
304 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S5G1
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,854
