跳转到主内容
Nokia Lumia 900 Motherboard Replacement
你所需要的
  1. 注意:步骤 1 源自标记为进行中的 指南
    Nokia Lumia 900 Motherboard Replacement, Opening The Phone: 步骤 1 中的图像 1,2 Nokia Lumia 900 Motherboard Replacement, Opening The Phone: 步骤 1 中的图像 2,2
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Motherboard Replacement, Removing the Battery: 步骤 2 中的图像 1,1
    • Detach connector from the phone.
    • Use the opening tool to pry out battery from the phone.
    • The battery should come out fairly easily
  3. Nokia Lumia 900 Motherboard Replacement, Detach the Screen: 步骤 3 中的图像 1,1
    • Detach Connectors that are attached from the screen to the motherboard.
    • Screen can now be removed with little effort.
  4. Nokia Lumia 900 Motherboard Replacement, Removing Rubber Gaskets: 步骤 4 中的图像 1,1
    • Using a pair of tweezers, remove rubber gaskets that are holding the motherboard in place.
  5. Nokia Lumia 900 Motherboard Replacement, Removing the Motherboard: 步骤 5 中的图像 1,1
    • Starting in the bottom left corner of the device, insert a wedge between the motherboard and the case.
    • Gently pull up with the wedge allowing for the motherboard to gently click out of place.
    • Gradually repeat this process around the entire motherboard until it becomes easy enough to remove completley from the casing.
结论
2等其他人完成本指南。
Joshua Crosman
于10/20/14注册
304 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S5G1
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,632
