你所需要的
步骤 1 Opening The Phone
注意:步骤 1 源自标记为进行中的 指南。
Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
Using the opening tool, pry the screen from the casing until they are separated from each other.
Apply adhesive to back of camera
Attach ribbon to motherboard
Press down on camera for 60 seconds
Let dry for 5 minutes
Slide the hinges of the left side of the screen under the left side of the plastic case
Clamp the right side of the screen down and make sure screen is flat
The screen should "click" into place
另外一个人完成了本指南。
