跳转到主内容
Nokia Lumia 720 Logic Board Replacement
你所需要的
视频概述
  1. Nokia Lumia 720 Logic Board Replacement, BATTERY COVER - PART 1: 步骤 1 中的图像 1,3 Nokia Lumia 720 Logic Board Replacement, BATTERY COVER - PART 1: 步骤 1 中的图像 2,3 Nokia Lumia 720 Logic Board Replacement, BATTERY COVER - PART 1: 步骤 1 中的图像 3,3
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Logic Board Replacement, BATTERY COVER - PART 2: 步骤 2 中的图像 1,3 Nokia Lumia 720 Logic Board Replacement, BATTERY COVER - PART 2: 步骤 2 中的图像 2,3 Nokia Lumia 720 Logic Board Replacement, BATTERY COVER - PART 2: 步骤 2 中的图像 3,3
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Logic Board Replacement, Loudspeaker & Antenna module: 步骤 3 中的图像 1,3 Nokia Lumia 720 Logic Board Replacement, Loudspeaker & Antenna module: 步骤 3 中的图像 2,3 Nokia Lumia 720 Logic Board Replacement, Loudspeaker & Antenna module: 步骤 3 中的图像 3,3
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
  4. Nokia Lumia 720 Logic Board Replacement, BATTERY: 步骤 4 中的图像 1,3 Nokia Lumia 720 Logic Board Replacement, BATTERY: 步骤 4 中的图像 2,3 Nokia Lumia 720 Logic Board Replacement, BATTERY: 步骤 4 中的图像 3,3
    • Disconnect the battery flex cable.
    • Unstick the metal foil from the logic board.
    • Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
    • Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
  5. Nokia Lumia 720 Logic Board Replacement, COAXIAL ANTENNA CABLE: 步骤 5 中的图像 1,3 Nokia Lumia 720 Logic Board Replacement, COAXIAL ANTENNA CABLE: 步骤 5 中的图像 2,3 Nokia Lumia 720 Logic Board Replacement, COAXIAL ANTENNA CABLE: 步骤 5 中的图像 3,3
    • Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
  6. Nokia Lumia 720 Logic Board Replacement, Logic Board: 步骤 6 中的图像 1,3 Nokia Lumia 720 Logic Board Replacement, Logic Board: 步骤 6 中的图像 2,3 Nokia Lumia 720 Logic Board Replacement, Logic Board: 步骤 6 中的图像 3,3
    • Disconnect the Volume, Power and camera buttons flex cable.
    • Remove the 4x Torx T4 screws.
    • Slightly lift the board
    • Slowly and gently unstuck the light sensor from the middle frame.
  7. Nokia Lumia 720 Logic Board Replacement: 步骤 7 中的图像 1,3 Nokia Lumia 720 Logic Board Replacement: 步骤 7 中的图像 2,3 Nokia Lumia 720 Logic Board Replacement: 步骤 7 中的图像 3,3
    • Disconnect the Display Assembly flex cable.
    • Disconnect the Charging Dock Board flex cable.
    • Remove the Main board.
结论
ZFix
于12/09/13注册
192,056 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 899
