跳转到主内容
Nokia Lumia 720 Battery Replacement
你所需要的
视频概述
  1. Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 1: 步骤 1 中的图像 1,3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 1: 步骤 1 中的图像 2,3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 1: 步骤 1 中的图像 3,3
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 2: 步骤 2 中的图像 1,3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 2: 步骤 2 中的图像 2,3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 2: 步骤 2 中的图像 3,3
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Battery Replacement, Loudspeaker & Antenna module: 步骤 3 中的图像 1,3 Nokia Lumia 720 Battery Replacement, Loudspeaker & Antenna module: 步骤 3 中的图像 2,3 Nokia Lumia 720 Battery Replacement, Loudspeaker & Antenna module: 步骤 3 中的图像 3,3
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
  4. Nokia Lumia 720 Battery Replacement, BATTERY: 步骤 4 中的图像 1,3 Nokia Lumia 720 Battery Replacement, BATTERY: 步骤 4 中的图像 2,3 Nokia Lumia 720 Battery Replacement, BATTERY: 步骤 4 中的图像 3,3
    • Disconnect the battery flex cable.
    • Unstick the metal foil from the logic board.
    • Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
    • Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
结论
另外一个人完成了本指南。
ZFix
于12/09/13注册
192,056 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
3条评论
I have nokia lumia 720....it can't starting up only shows charging sing..... plz...help me
Amir Hosain - 回复
i have also the same problem is ur problem fixed now ..then pls tell me the solution
pattnayakabhash34 -
Hey guys I really need to know if you can recommend a trusted retailer of spare BP-4GWA here in South East Asia. I am currently residing in the Philippines and it's just hard to buy from Ebay and Alibaba without anyone's opinion. TIA!
nicoangelob - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 5,684
