跳转到主内容
Nokia Lumia 635 Headphone Jack Replacement
你所需要的
  1. Nokia Lumia 635 Headphone Jack Replacement, Battery Removal: 步骤 1 中的图像 1,2 Nokia Lumia 635 Headphone Jack Replacement, Battery Removal: 步骤 1 中的图像 2,2
    • Open the back case of the phone using the plastic opening tool.
    • Remove the battery.
  2. Nokia Lumia 635 Headphone Jack Replacement, Screw Removal: 步骤 2 中的图像 1,2 Nokia Lumia 635 Headphone Jack Replacement, Screw Removal: 步骤 2 中的图像 2,2
    • Remove the six screws shown in the photo using the torx Screwdriver 5mm.
    • Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
  3. Nokia Lumia 635 Headphone Jack Replacement, Remove Hidden Screw: 步骤 3 中的图像 1,2 Nokia Lumia 635 Headphone Jack Replacement, Remove Hidden Screw: 步骤 3 中的图像 2,2
    • Remove the black sticker on the bottom left side (As shown in the picture).
    • Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
  4. Nokia Lumia 635 Headphone Jack Replacement, Separating Back Cover From Screen: 步骤 4 中的图像 1,1
    • Using the plastic opening tool separate the plastic cover from the screen.
    • On the top left corner you will see the screens flex attached to the mother bothered, watch out when separating them.
  5. Nokia Lumia 635 Headphone Jack Replacement, Audio Jack Replacement: 步骤 5 中的图像 1,1
    • Carefully retrieve the audio jack’s flex that is attached to the mother board as shown in the picture.
    • Attach the new audio jack’s flex to the mother board.
结论
3等其他人完成本指南。
Benjamin
于10/07/14注册
173 声望
撰写一个指南
团队
USF Tampa, Team 7-1, Leahy Fall 2014 USF Tampa, Team 7-1, Leahy Fall 2014 的会员
USFT-LEAHY-F14S7G1
4 名成员
创作了16篇指南
一条评论
where can you buy the headphone jack?
fERD - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 5
总计 4,904
