跳转到主内容
Nokia Lumia 635 630 Display Assembly Replacement with Frame
你所需要的
视频概述
  1. Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: 步骤 1 中的图像 1,3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: 步骤 1 中的图像 2,3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: 步骤 1 中的图像 3,3
    • Remove the battery and any SIM and memory cards.
    • Remove the black sticker at the bottom side of the phone.
  2. Nokia Lumia 635 630 Display Assembly Replacement with Frame: 步骤 2 中的图像 1,3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 步骤 2 中的图像 2,3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 步骤 2 中的图像 3,3
    • Use a screwdriver Torx T4 and remove the 7x screws.
    • There are two other smaller screws with the same head size – remove them as well.
    You need a decent quality T4 screwdriver here - the rubbish on that cm free with the screen assembly I bought failed completely to grip or loosen the screws. With one from a decent set (ForgeSteel from ScrewFix) they came out easily. A fridge magnet is useful to keep the screws on.
    jeremyyoung - 回复
  3. Nokia Lumia 635 630 Display Assembly Replacement with Frame: 步骤 3 中的图像 1,3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 步骤 3 中的图像 2,3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 步骤 3 中的图像 3,3
    • Lift the rear bezel and unhook the display assembly flex cable.
    • Don't use a metal tool for disconnecting the flex cable. There are many small elements near the connectors. You could break them. If you don't have a suitable tool just use your nails.
    • Now we have to transfer the earpiece.
  4. Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: 步骤 4 中的图像 1,3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: 步骤 4 中的图像 2,3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: 步骤 4 中的图像 3,3
    • Put the earpiece on the new display assembly and start with reassembling.
结论
17等其他人完成本指南。
ZFix
于12/09/13注册
191,368 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,468篇指南
2条评论
Where do i get the part replacements from to replace the screen and what not?
Nathaniel Ogungbuyi - 回复
Großes Lob an Nokia, das ist noch ein super zu öffnendes Smartphone gewesen! Touchdisplay tauschen war einfach.
Tale Spinner - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 10,342
