跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
Nokia Lumia 635, 630 - 硬格式化
视频概述
  1. Nokia Lumia 635, 630 - 硬格式化, Nokia Lumia 635, 630 - 硬格式化: 步骤 1 中的图像 1,3 Nokia Lumia 635, 630 - 硬格式化, Nokia Lumia 635, 630 - 硬格式化: 步骤 1 中的图像 2,3 Nokia Lumia 635, 630 - 硬格式化, Nokia Lumia 635, 630 - 硬格式化: 步骤 1 中的图像 3,3
    • 关闭手机
    • 按住电源键直到手机振动,然后松开电源键的同时长按音量减键。正确执行这一操作后,你将能看见屏幕上显示一个感叹号。
    • 另外一种进入硬复位模式的方式:按住音量减键并同时连接电源。
    • 当屏幕上出现感叹号后,依次按下下列按键
    • -> 音量加键
    • -> 音量减键
    • -> 电源键
    • -> 音量减键
    Mine won't go to ! It keeps rebooting to Nokia
    Trillix Wolfie - 回复
    My phone ignores the sequence. It was set up as a child phone, and there’s no “reset phone” button in the about menu. It in fact doesn’t even have the about menu. And trying to reset it using buttons, I get exclamation mark, and once I push the Volume Up button, it starts to boot normally and ignores the rest.
    Sergey Kofanov - 回复
    THanks its a useful ways it works on my phone…nice one
    Abasi Kadewele - 回复
    thank you it worked on my phone!!! I’m very glad! Thank you again!
    szabo_istvan78 - 回复
    When I turn on my Lumia 635, it displays "Nokia" and goes off then comes on again and only display Nokia. After resetting it, it continues the same
    Frank Inyiama - 回复
    my lumia phone was switch off showing Nokia sign in every 10 seconds. after hard reset , it is showing charging sign. what to do next .
    flora - 回复
    Thank you, it worked on my phone. I’m very happy now
    Arham Jahangir - 回复
    Works perfectly,
    thanks.
    And just a note for everyone, TAKE YOUR SD CARD OUT FIRST!!!!! IT WILL WIPE THE DATA!!!!
    Austin Wilson - 回复
    Worked perfectly thank you for this info!!
    jessiecrego83 - 回复
    non riesco a resettare il mio lumia, sarà perchè il sistema operativo è stato aggiornato con il 10?
    qualcuno può suggerirmi qualcosa?
    rosario marchica - 回复
结论
此操作执行后无法恢复
63等其他人完成本指南。
由衷感谢以下译者:
en zh
75%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
ZFix
于12/09/13注册
191,308 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,532篇指南
32条评论
Hey, I have done it on the computer, reload the windows but still I get the exclamanition, also the battery is death right now and I don't know how its gonna charge?
remzicanakile - 回复
Phone get rain water, I want to mention it.It opens dont problenm but that sign (!) gonna drive me mad!!
remzicanakile - 回复
Will this delete contact numbers
suryansh - 回复
Yes if you have the numbers stored somewhere not on the phone then you just have to re add them
Abigail Hard -
will my number still be there and is the phone still active, Do I need to have it reactivated??
or should i take out the sim card first??
robcamp1963 - 回复
Now would I bypass a reset protection notification
STUDENT James Chapman - 回复
its work tnk u... : )
chandanso37 - 回复
It worked for me....thanks a whole lot.....am happy
Christian smart -
Its very Useful... Thank you.... -:)
Madhu K - 回复
It didn't work now I have a sad face on the screen and phone won't cut on
Monicia - 回复
It does not work!!
Katie Frisby - 回复
me too it does not work! and why ?
queeniebautista - 回复
It works.. Thanksss... :)
syedhuzaifa96 - 回复
Thanks a million. It worked and a huge problem solved. Thanks again.
Ibrahim Nisar - 回复
When I turn on my Lumia 630, it displays "Nokia" and goes off then comes on again and only display Nokia....will this method bring it back to normal?
Christian smart - 回复
Mine is the same too. I don't know what to do
Frank Inyiama -
It worked... thanks a bunch
It's not working, I repeated the process multiple times and I keep getting the same outcome, it just goes to the Nokia screen, and boots up the same
Anthony Martin - 回复
I have done it but still facing the same problem. The problem is that my sister has given me Nokia Lumia 635 and it is having a problem of ‘This device is locked to a specific mobile operator. Contact your mobile operator for the unlock code.
Beal Geesus - 回复
This method always had worked for me.
Manheche Baptista - 回复
This method always really worked for me.
thank you very much. the method is really superb
sssebyongaabdulnoor - 回复
Not work for me. Hardware reset done. anyway thanks for the details.
Pabodha Lankathilaka - 回复
Wow its working
Kenyi paul - 回复
There is a sad face and the phone won't start
Henry Ncube - 回复
Phone shows a sad face and will not open
Henry Ncube - 回复
the phone loads up to a blue screen then says complete and also says below it if you'd like to know more you can search online later or this and onto of that it says 0% then error.0xc00002e3
carlos gonzalez - 回复
It’s doesn’t work!
Sophia Parsons - 回复
how on god’s green earth are you going to do this “to reassemble your device follow this backward” bro, it’s a Fudging factory reset, not a dissasembaly
alexgamertheminer - 回复
Hallo, ich habe noch ein altes Nokia RM 974 in grün. Ich habe einen Hard-Reset durchgeführt. Nach den beiden Zahnrädern kommt aber leider nur ein ablehnendes und es resettet neu, und alles wiederholt sich. Haben Sie dafür eine Lösung?
Ralf Hader - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 43
过去 30 天: 206
总计 238,031
