跳转到主内容
Nokia Lumia 620 Volume and Power Button Replacement
你所需要的
  1. Nokia Lumia 620 Volume and Power Button Replacement, Volume and Power Button: 步骤 1 中的图像 1,1
    • Check condition of switches on logicboard
    • Rule out failure of cover
  2. Nokia Lumia 620 Volume and Power Button Replacement: 步骤 2 中的图像 1,1
    • Torx 6 screwdriver
    • Soldering iron (thin tip)
    • Decent quality solder (thin wire)
  3. Nokia Lumia 620 Volume and Power Button Replacement: 步骤 3 中的图像 1,1
    • Remove cover, battery and SIM
    • Remove 6 torx screws
    • Note: Green is fine thread
    • Note: Red is coarse thread
  4. Nokia Lumia 620 Volume and Power Button Replacement: 步骤 4 中的图像 1,2 Nokia Lumia 620 Volume and Power Button Replacement: 步骤 4 中的图像 2,2
    • Remove plastic clover near battery
    • Keep track of all parts
  5. Nokia Lumia 620 Volume and Power Button Replacement: 步骤 5 中的图像 1,1
    • Gently release logicboard connectors
  6. Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: 步骤 6 中的图像 1,2 Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: 步骤 6 中的图像 2,2
    • There is a clip that needs to be moved out of the way before the board will move.
    • Start by lifting long side of logicboard
    • Gently wiggle and lift
    • Undo plastic clips near battery with force
  7. Nokia Lumia 620 Volume and Power Button Replacement: 步骤 7 中的图像 1,1
    • Check connections of failed buttons
  8. Nokia Lumia 620 Volume and Power Button Replacement: 步骤 8 中的图像 1,1
    • Resolder broken connections
    • Make sure the pads do not short
  9. Nokia Lumia 620 Volume and Power Button Replacement: 步骤 9 中的图像 1,1
    • Put back logicboard
    • Make sure pins near camera line-up
    • Note: Plastic clips need quite some force
  10. Nokia Lumia 620 Volume and Power Button Replacement: 步骤 10 中的图像 1,1
    • Reconnect logicboard connectors
  11. Nokia Lumia 620 Volume and Power Button Replacement: 步骤 11 中的图像 1,1
    • Put back plastic cover
  12. Nokia Lumia 620 Volume and Power Button Replacement: 步骤 12 中的图像 1,1
    • Gently tighten screws
    • Put back SIM card and battery
    • Close cover
    • Enjoy the result ;)
终点
11等其他人完成本指南。
Anne
于10/17/14注册
456 声望
撰写一个指南
4条评论
Realmente funcionó el tutorial, sirven de nuevo los dos botones que fallaban.
Gaia501 - 回复
Only the 2 middle screws are fine threaded. And you can see in the pictures here, that there are 4 coarse threaded ones and 2 fine threaded ones. The green one in the corner should be red
shadow118 - 回复
hafıza kart okuyucu çalışmıyor ne yapmam lazım
davutcigir - 回复
Omg it looks complicated
Maz Hanvey - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 10,170
