跳转到主内容
Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement
你所需要的
视频概述
  1. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: 步骤 1 中的图像 1,2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: 步骤 1 中的图像 2,2
    • Switch off the phone and remove the battery.
  2. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 2 中的图像 1,3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 2 中的图像 2,3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 2 中的图像 3,3
    • Remove 8x Torx T5 screws.
    • With a plastic tool, start with separating the middle frame from the down side.
  3. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 3 中的图像 1,2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 3 中的图像 2,2
    • The Loudspeaker is on the middle frame.
    • Disconnect the LCD Display flex cable.
    • Disconnect the Touch screen flex cable.
  4. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 4 中的图像 1,3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 4 中的图像 2,3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 4 中的图像 3,3
    • The Logic board is held by 2x locking clips at the bottom side.
    • Release it and gently remove it from the front frame.
  5. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 5 中的图像 1,3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 5 中的图像 2,3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 5 中的图像 3,3
    • Put tape on the glass to not scatter pieces.
    • Worm the glass to melt the adhesive.
    • Use plastic tools to separate the touchscreen from the frame.
  6. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 6 中的图像 1,3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 6 中的图像 2,3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 6 中的图像 3,3
    • After separating, clean up the sticker that remains on the borders.
    • New line.Install the new touchscreen and reassemble the device.
  7. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: 步骤 7 中的图像 1,1
    • That's all.
    • Did you do it successfully?
结论
4等其他人完成本指南。
ZFix
于12/09/13注册
191,182 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,521篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 1,871
