跳转到主内容
Nokia Lumia 521 SIM Card Replacement
你所需要的
  1. Nokia Lumia 521 SIM Card Replacement, Battery: 步骤 1 中的图像 1,2 Nokia Lumia 521 SIM Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 SIM Card Replacement: 步骤 2 中的图像 1,1
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
  3. Nokia Lumia 521 SIM Card Replacement, SIM Card: 步骤 3 中的图像 1,1
    • After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
结论
Marko Stanisic
于02/10/16注册
322 声望
创作了2篇指南
团队
USF Tampa, Team 2-4, Sullivan Spring 2016 USF Tampa, Team 2-4, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 1,538
